# Wyze Cam - How many simultaneous connections to the camera for online viewing  ?
**URL:** <https://forums.wyze.com/t/wyze-cam-how-many-simultaneous-connections-to-the-camera-for-online-viewing/6135>\
**Category:** Cameras\
**Tags:** cam-v1-v2\
**Created:** [September 10, 2018, 2:02pm UTC](https://forums.wyze.com/t/wyze-cam-how-many-simultaneous-connections-to-the-camera-for-online-viewing/6135 "2018-09-10T14:02:46Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![lik\_81](https://avatars.discourse-cdn.com/v4/letter/l/f14d63/32.png) [@lik\_81](https://forums.wyze.com/u/lik_81)\
**Post date:** [September 10, 2018, 2:02pm UTC](https://forums.wyze.com/t/wyze-cam-how-many-simultaneous-connections-to-the-camera-for-online-viewing/6135/1 "2018-09-10T14:02:46Z")
</div>
Hello! I have a question for you. If I do share access to view online for my family members how many simultaneous connections can I have?
**Author:** ![Loki](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/loki/32/1595_2.png) [@Loki](https://forums.wyze.com/u/Loki)\
**Post date:** [September 10, 2018, 3:12pm UTC](https://forums.wyze.com/t/wyze-cam-how-many-simultaneous-connections-to-the-camera-for-online-viewing/6135/2 "2018-09-10T15:12:26Z")
</div>
You can stream a single camera to multiple devices at the same time. How many will work depends on whether the devices are on the local network or remote and your internet speed. Since it so much depends on your individual situation, the only way to know is to try. If you stream in SD (instead of HD) it will use less bandwidth and therefore potentially support a greater number of connections. There is a new feature (beta only for now I think) that allows streaming at 360p, which will use even less bandwidth.
