Wyze cam and Echo show in Brazil setup issues
Hello I bought a Wyze ca,m and an echo show in the usa and ytook it with me to brazil , was able to set up my wyze can on my celphone ( Iphone) and was able to set up my echo show , but…
It looks like the integration for wyze cam to echo show is only for the USA the skill does not show up in my amazon account , any suggestion on how to get the image from my wize cam to my echo show , I bought this mainly as nany cam ,
Welcome @msteingr
I believe you can change the Region on the show to somewhere in the US. Something like this:
  1. Using the Alexa App:
  • Open the Amazon Alexa app on your smartphone or tablet.
  • Sign in with your Amazon account credentials.
  • Tap the menu button (usually three horizontal lines) in the upper-left corner.
  • Select Settings.
  • Choose your Amazon Echo device from the list.
  • Tap Edit under Device location.
  • Select your desired country from the list and add your address.
  1. Using the Amazon Alexa Website:
  • Log in to the Amazon Alexa website.
  • Go to Settings and select your Alexa device.
  • Scroll down to Location and click Edit.
  • Choose the country from the list at the top.
