Wyze cam 3 and 4 power adapter failed
I have 3 of power adapters for wyze cam 3 and 4 that have failed after about one or two years of continuous operation and I could not find the replacement. I wished Wyze included outdoor rated power adapter since the cam was intended for use both indoor & outdoor. Now it looks like I have to buy an extra universal outdoor power adapter for $19.99 when the cam v4 itself is selling for about $29.99 +/-.
Welcome to the forum @tedtris .
Myself and some other forum members chose not to use Wyze adapters. I use double port 4.8A 24W adapter on all my cameras. They are similar to this one:
Nekmit Dual Port Ultra Thin Flat USB Wall Charger with Smart IC, White (White) : Amazon.ca: Electronics
I’ve had them since mid 2022.
It fits snugly inside a weather proof in use box plugged into a smart plug. Keep in mind that in order for Wyze to keep the price low on its cameras they need to cut corners somewhere. I think adapters are one of those things.
Thank you for the input, @habib . I will follow the recommendation asap. Appreciate for sharing the info with me.
My pleasure!
