Can Wyze bulb be turned on using motion activation?
Yes, you set it up to turn on via the camera or motion sensor.
Would you be able to describe where this is found in the app? When I go to the options for a moon sensor, I only get options about turning notifications on or off.
Just got my bulbs and I am excited to turn them on with the sensors.
Thanks!
I just ran into the same thing. It’s a little confusing. I’m the app, tap the 3 dots in the top right, edit shortcuts, create shortcuts, choose your action, then turn on automate and select your sensor. Hope that helps!
Ahh! That was it. The automate option!
I kept seeing the sensor videos and whatnot where it says like “hey something’s moving!, Okay I’ll record it”
But couldn’t find the option to say “hey something’s moving, okay I’ll turn on!”
Thank you thank you for the quick response!
