Wyze Bulb flashes 2 short, 1 long - what does it mean?
My bulbs flash a code when plugged into my entryway ceiling light socket - 2 short, 1 long. It’s completely unresponsive otherwise.
I checked out the bulb in another light fixture and it works just fine.
I can only assume something is wrong with the the voltage or something else in the socket that triggers the flashing code. Any clue? I just moved into the place so who knows what electrical issues I’m going to find.
Thanks!
Is that bulb controlled by a dimmer switch? Smart bulbs need full power.
