So I got a 2 pack of the wyze bulbs white about 2 weeks ago . Have loved them so far but I’m running into an issue with my smart bulbs since I got them…
So the bulb will go offline repeatedly , about every 3 days . The app will show its offline , i go and turn off the lamp where the numb is screwed into , and even unscrew the bulb and screw it back into the socket but it still fails to get back online
I have to delete the device and set it up again to add it and get it online .
Another wyze device of mine that has given me nothing but problems :////
If it’s a singular bulb having issues (this one and not others), after making sure it’s up to date on firmware, etc, contact support. It could be an individual bulb issue. I know a few people have had similar things resolved with replacements in the past, so it’s worth asking about.
If it is multiple bulbs doing this to you, I am guessing it is the router issue, and hopefully your new Mesh router will help with this soon. Even if it is just a single bulb having this issue and not others, it could be an issue based on the placement/location and signal concerns. I think the new mesh you’re looking at will help with this a lot.
