disable / enable Wyze Skill worked, thanks!
Disable/enable worked for me: credit to rmblaster1 from July 12, toward the beginning of this thread.
Thanks!
Had similar discovery issue with light bulb. Never showed up as discovered but once I gave a verbal command to “turn on the light”, it was there. That is not working for the cameras though. Followed all of the suggestions about (disable/enable skills, recycled devices and Alexa…). Any next suggestions??
This worked. Thank you!
