# Wyze App - weak time frame line
**URL:** <https://forums.wyze.com/t/wyze-app-weak-time-frame-line/5458>\
**Category:** Power & Lighting\
**Tags:** support\
**Created:** [June 20, 2018, 12:03am UTC](https://forums.wyze.com/t/wyze-app-weak-time-frame-line/5458 "2018-06-20T00:03:50Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![csm31458](https://avatars.discourse-cdn.com/v4/letter/c/4da419/32.png) [@csm31458](https://forums.wyze.com/u/csm31458)\
**Post date:** [June 20, 2018, 12:03am UTC](https://forums.wyze.com/t/wyze-app-weak-time-frame-line/5458/1 "2018-06-20T00:03:50Z")
</div>
hi Wyze Dev App Team
Am using the wyze cam and about the camera have only one issue: during the dark light it still records in colour mode \> maybe it would be better to record in grey-scale mode?
But I do have a problem with the app: The colours are problem: white background , light-green time movement marks and thick darker-a-little-green time-pointer
That makes almost impossible to point exactly to the time you wanna view.
Please check how YI Home App works , that might be a good inspiration how it should work. If you can’t check that app for some reason then let me know and I’ll make video for you.
rgds, R
**Author:** ![Loki](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/loki/32/1595_2.png) [@Loki](https://forums.wyze.com/u/Loki)\
**Post date:** [June 20, 2018, 5:13am UTC](https://forums.wyze.com/t/wyze-app-weak-time-frame-line/5458/2 "2018-06-20T05:13:08Z")
</div>
Do you have night mode set to Auto? Tap the night mode symbol above right of the live stream view.
When viewing the timeline, move to the general area you want to view. Then use a pinch-out gesture on the timeline. It will expand to give you much finer control over placement of the playback marker.
**Post date:** [June 20, 2018, 10:58pm UTC](https://forums.wyze.com/t/wyze-app-weak-time-frame-line/5458/3 "2018-06-20T22:58:21Z")
</div>
@Rick0
Thank you for your reply , that pinch-out tip works. but it would be better if app automatically expand the time-frame-line
do you know if there is or will be dark theme for iOS app ?
**Post date:** [June 21, 2018, 6:14am UTC](https://forums.wyze.com/t/wyze-app-weak-time-frame-line/5458/4 "2018-06-21T06:14:34Z")
</div>
Sorry, I’ve not heard anything about a dark theme. Don’t know one way or the other.
