Wyze App V2.11.41 Issues
TY Omgitstony, I now can do that!!!
Yep, you got to get a iPhone
Spoilsport
You left out the very best part… They went from around dots to squares
My problem is if I delete them on my iPad they are not deleted on my iPhone.
Do they update each other on other applications… Or is it just the Wyze application?
I only use the Wyze app on both devices. Both updated to latest versions.
Gotta both be on same network (and maybe on cloud) and both on the same account
Try using notes and see if both work (update each other)
