Wyze app using up hotspot data
I have a cell plan with unlimited data usage but my hotspot data (whatever that is) is limited ot 10GB. The Wyze app keep using tons of hotspot data quickly reaching my limit of 10gb/month. Why isn’t it using the unlimited data as opposed to the hotspot data?
Are you able to turn off Hotspot & Tethering on Android?
My phone works the same way. Hotspot data works differently than on-the-phone data when you use phone apps. I have unlimited data but my hotspot is capped at 5GB.
Maybe try tethering? I haven’t tried that or had a need to.
I’m afraid that hotspot and tethering are already disabled.
Might be a question for your cell carrier to answer why you are billed for hotspot data when it is disabled.
Thanks, that sounds like good advice.
Question, how are your cameras connected to the internet?
