It used to be that my email address was saved in the Wyze app and all I had to do was enter my password to log in. No more. I have to enter my email address AND my password to log in to the Wyze app, and it is becoming increasingly frustrating and inconvenient.
Is there a way to save my email address and/or password to the Wyze app so I DON’T have to enter it every time I want to monitor my cameras?
That is a function of your phone settings not the Wyze app. In your phone settings open your Passwords tab. Then select Password Options on the next screen be sure to have “Auto-Fill” selected. That way any password you enter will be stored on your phone and will prompt you when needed to access an App or Website. Good luck
And make sure “Clean up Automatically” is turned off.
There is no passwords tab on my iPhone.
Sorry, not applicable to iphone 8+. At least, not my iPhone running IOS 16.7.1
Password settings are on all iPhones, all iOS versions. Just need to find it. I don’t remember where they were under iOS 16… I think it’s a toggle setting at Settings > Touch ID & Passcode > Password AutoFill. There should be another area at Settings > Passwords > AutoFill. This is where you can specify where your passwords are saved and also toggle the feature on/off.
It’s already enabled. I don’t know what is wrong with the Wyze app so I deleted and reinstalled it. Maybe that will help.
