Wyze app integration for Android app on Chrome OS has an aspect ratio glitch
When trying to put a video feed into full screen mode on the Android OS app installed on Chromebook it doesn’t work because a Chromebook doesn’t have a gyroscope in it to tell the application to flip aspect ratios. An option to lock aspect ratio to horizontal in the app would be nice so that it will work on a Chromebook that cannot use a gyroscope function to determine which orientation the screen is already in. Unlike tablets that have the gyroscope that assists in orientation flips.
my 3 cents.
In the upper right corner there is a square icon. If you tap that, it takes you to full screen mode. This works for me in my Android emulator.
I to would like my Wyze app to work better on my Chromebook. Thanks
