Add a setting within the app to change the default “home” view from all devices to the “Monitoring” view for those subscribed to HMS.
Absolutely!
Would love the ability to designate which tab gets the privilege of owning my Default View designation! HMS would be my first choice!
Don’t forget to vote for your own thread!
Put a short cut on your phone for the HMS. That what I do. Works on Android.
Unfortunately, the Wyze HMS Widget varies in size depending on the phone. On Android 11 Moto, for example, it is a massive 3x3 block for a 2x2 button that takes up half the real estate available.
When Wyze gets better Widgets, perhaps it will be beneficial.
