noticed with the new app version 3.1.6(1). on IOS , the download of Timelapse captures from the album section is as slow AF. apart from crashing all the times , sometimes it resumes other times it just starts from 0% again.
Also why are the captures from v3 cam twice the size of the v3 pro , I thought with the higher resolution it would be the other way around. for example I run a 8hour capture at 3sec over night , the file size on the v3 is 1.6Gb , the same on the v3 pro is only 860Mb?
The resulting file size also depends on how complex the images are. For example a white image compresses to a few bytes. Are you capturing the same scene for both cameras?
Also the V3pro has a better hardware and can can compress more.
the Timelapse runs over night , so it’s all under IR and mainly stationary objects with the occasional cat running through the frame , one camera points east the other west , so it’s a similar scene . if it would vary I wouldn’t be surprised , but it’s almost always half the size
