sd card will not fit in wyze v3 camera slot. Card goes in crooked
Hello @crdreshman and welcome to the community.
I am guessing you have the card facing the wrong direction, turn it around the other direction if it starts to go crooked on inserting it.
Hey Jason21271 , I did what you said it got swallowed it up but I got it back. I had another new V3 and it didn’t work in it either. I did buy another WYZE micro card with my order. I may try it or buy one from BEST BUY to try.
I noticed that the card that I have been trying has a piece starting to break off. SOL. I did not have any problem with my WYZE cam v2
Thanks for your response
