I have the WRV in my office for testing before I take it to my house. The office area I’m in is fairly large and has quite a few access points in and around it. The vacuum seems to have a preferred access point and it hangs onto it as it goes around the building. Eventually, it’ll loose connectivity because of the distance and number of walls between the vacuum and AP. Despite that, it never roams. The parallel for home users would be folks who have mesh access points or repeaters. I’m guessing the WRV gets the first BSSID it sees and then holds onto it indefinitely.
Is there any logic or programming to handle roaming? Even if it’s an ugly drop and reconnect. It doesn’t support 11k, r, or v. I’m adding some stats/data from the wireless controller just give a feel for what’s around. I’ve done a pcap of it just for funsies but I’m not sharing that here for privacy reasons. The vacuum is connected to a dot1x/RADIUS server so I cut that portion of the logs out as well.
Client:
Modulation… mcs13 ss1
Radio Capability… 802.11n
CF Pollable… Not implemented
CF Poll Request… Not implemented
Short Preamble… Implemented
PBCC… Not implemented
Channel Agility… Not implemented
Listen Interval… 3
Fast BSS Transition… Not implemented
11v BSS Transition… Not implemented
Stats:
Number of Bytes Received… 6011114
Number of Bytes Sent… 2259005
Total Number of Bytes Sent… 2259005
Total Number of Bytes Recv… 6011114
Number of Bytes Sent (last 90s)… 2833
Number of Bytes Recv (last 90s)… 2741
Number of Packets Received… 14069
Number of Packets Sent… 8605
Number of Interim-Update Sent… 10
Number of Data Retries… 20304
Radio Signal Strength Indicator… -59 dBm
Signal to Noise Ratio… 33 dB
Client Detected as Inactive… No
Roaming candidates:
XX-CURRENT-AP-XX(slot 0)
antenna0: 6580 secs ago… -52 dBm
antenna1: 6580 secs ago… -52 dBm
XX-ANOTHER-AP-XX(slot 0)
antenna0: 6581 secs ago… -84 dBm
antenna1: 6581 secs ago… -81 dBm
antenna0: 6581 secs ago… -90 dBm
antenna1: 6581 secs ago… -90 dBm
antenna0: 6580 secs ago… -77 dBm
antenna1: 6580 secs ago… -80 dBm
antenna0: 6581 secs ago… -61 dBm
antenna1: 6581 secs ago… -61 dBm
antenna0: 6580 secs ago… -91 dBm
antenna1: 6580 secs ago… -91 dBm
antenna0: 6580 secs ago… -84 dBm
antenna1: 6580 secs ago… -84 dBm
antenna0: 6580 secs ago… -69 dBm
antenna1: 6580 secs ago… -69 dBm
