Won't Enter Setup
Just bought 3 V2’s. 2 of them set up with no problem.3rd one has flashing yellow light but pushing setup does nothing. Any ideas?
If removing and restoring power doesn’t help, then try holding down the setup button for 20-30 seconds to do a factory reset.
That button seems to have no effect at all. Opened a ticket with support.
Thanks for the reply.
