I formatted and installed a micro SD card in my new WOC. When I go to Settings/MicroSD Card Storage I see that the card is inserted. I formatted it in the WOC to be sure that it was properly configured. I currently have a bar that shows 0.0G/29.7G. After doing this I went to the camera and saw I had an event and below it said “View Playback.” I clicked assuming I would see the playback from the camera and instead got a “Video playback is not supported.”
Then I inserted a 2nd SD card in my base station. Again, I see the 0.0G/29.7G. It’s properly formatted and working.
On WOC is continuous recording supported via SD card? If there’s an important even I want the entire event recorded. Because it’s a WOC and there are potential batter issues I can only assume continuous recording via SD isn’t supported?
What’s the purpose of the SD card? Is it so I can save clips and screenshots?
Why when watching the first event was there a ‘view playback’ button on the WOC like on my v3 camera that has a SD card?
As a side note, I noticed that even with my v3 camera only shows playback for an extended event and all other times it shows “there is no video.” Is Cam Plus required for my camera to continually record to my SD card? I remember in the past that with my V1 and v2 cameras I had a SD card and it recorded everything all the time but would trigger on events. Then I could see an event and look at the SD card extended recording if I wanted more details.
I was concerned that this would be the case so I bought the Cam Plus for $15/year on the camera. In this case, it at least continues recording until the event ends. If someone is robbing me and it’s all on camera then the camera should continue to record the entire event and upload it to the cloud, correct?
What’s the purpose of the SD card in the base station? Same thing? At what point does is the base station SD card used? What causes something to be saved to that video card? I thought maybe it serves as a proxy for the WOC recording but I guess not.
I looked for documentation and forum posts about all of this but couldn’t find anything specific. Any help sorting this all out would be greatly appreciated. Thanks!
EDIT: Update. As I give this more thought, maybe the SD card is if you want to use the WOC in standalone mode without the base station. I like this idea and plan to buy another camera to take to hotels with me and other locations that I’d like to have better security when I’m away from my personal belongings.
However, I bought the solar panel and plan to mount that. If the solar panel acts as my offsetting power source then why can’t I enable video recording?
