Window cares works live on iPad not on iPhone same network
New user here . Window cam live feature will not load for iPhone 14 latest iOS but works fine on iPad. iPhone gets error 21001 or says camera not on when it is on. No clue why.
Do you have the same iOS app on both devices 3.23.1 (3) ?
Can you confirm the error code is 21001?
Found references to code “20011 - Connection has timed out (error code 20011) Please try again.” but not 21001.
Also more info on type of Internet, Router, Mesh Network, … would be helpful.
Yes it is 21001 starlink internet everything is current versions. I only get the error on my iPhone not on iPad. . iPhone never loads live view it stalls . Yet I do get and can view events on iPhone
Just original Stalink 2nd generation router .
iPad Wyze app version 3.23.1.3
iPhone Wyze app version 3.23.1.3
iPhone iOS 26.7.1
iPad iOS 26.7.1
Window Camera version 1.3.0.63
Starlink software version 2026.09.18.mr87170.1
Starlink router model 2
Software version 2026.10.07.cr87930
If I go to live view on iPhone I see Loading livestream step 1 of 3 starting up secure connection. Then it just sits there with spinning circle . Finally spits up failed to connect Check internet connection error code G199.
If I go to monitoring page is see a static view of my outside overlaid with
Your camera is turned off. Which it is not as events still record and can be viewed on both iPhone and iPad live view can only be viewed on iPad. Along with the ability to set the detection zone on iPad only
iPhone iOS 26.7.1
iPad iOS 26.7.1
So iPad is connected to Wi-Fi and Livestream works.
Does iPhone Livestream NOT work on both Wi-Fi and 5G?
iPhone doesn’t work for live on wifi or cellular
Try this on your iPhone:
  • Use browser to open Wyze Web Portal and login using your Wyze credentials.
  • If you have a paid subscription you should see your camera Livestream .
  • If you don’t have a subscription you can activate 1 camera for Livestream for the calendar month.
Can you see your camera Livestream?
Yes I can
Sorry you’re dealing with this, it’s frustrating when the iPad works and the iPhone doesn’t. Since events still show up on the iPhone, the cloud side seems fine, so the problem is probably how the iPhone reaches the camera on your home network. On the iPhone, check Settings > Privacy & Security > Local Network and make sure the Wyze app is switched on, since iOS can block an app from reaching devices on your own Wi-Fi. Is it already enabled there?
Then it maybe something in your iPhone Wyze App settings.
Compare your iPhone and iPad settings under:
  • Settings > Privacy & Security > Local Network
  • Settings > Apps > Wyze App
If the settings are the same, then it might be an incompatibility between the Window Cam and your Starlink internet.
There have been issues reported with the new OG camera and cameras based on it like the Window Cam, when operating on high-latency internet services like Starlink and 5G.
Yes enabled
But iPad is also on starlink and works properly
Sorry … it’s just my opinion that based on the communication errors you are seeing on your iPhone:
  • Your camera is turned off.
  • failed to connect Check internet connection error code G199.
that the issue is the Starlink high latency.
For some reason your iPad handles it OK but your iPhone does not.
You can check the latency value:
  • Install Speedtest app on your iPhone
  • Connect your iPhone to Wi-Fi and run Speedtest at the location of your camera
  • Check the “Responsiveness” values in “Results”, e.g.
Final update. Both iPhone and iPad now work. Not sure why. I suspect it fixed after iOS 27 Both updated
