Wildlife not triggering events
Our municipality has gone from close to zero deer 15 years ago to over 100 on our urban streets. Our neighbours have had to add 6 foot plus fences to the front of properties breaking local byelaws to keep deer out of their front yards.
The number of deer vehicle accidents is increasing with injury/death to deer and damage sometime significant to vehicles ($2000-$10000+); and some residents are having to build $5000 front fences to keep deer out of their yards. Pets have been hurt and killed.
If Wyze Cam could clearly identify deer walking down the street or on the property this could help substantially with the inoculation program to reduce the number of deer. The deer need to be inoculated annually as the vaccination only lasts one year.
Some of the deer have trackers on them, and the municipality puts out cameras to help identify where they are. Wyze cams might be able to substantively help in this tracking process due to their reasonable cost, and possibly if a transaction record could be sent that could be added to an inventory identifying when the deer past a specific locations.
If I can get a clear identification of deer with time of day, and a 10 second snapshot, we might even be able to indicate deer that are tagged and the colour of their neck tags which helped to identify them and whether they’ve been previously inoculated.
As you may know there are probably hundreds, if not, thousands of towns and cities getting overrun by deer across North America, etc.
For consideration
The same thing could be done for bears, cougars, etc., in the city
All we need to do is send a transaction record to a shared Google spreadsheet which the municipality could then access
It could potentially even identify the GPS coordinates to help map where they are
This could help to reduce deer injuries as well as vehicle damage, as well as expense to homeowners having to build fences.
Wasn’t that a show on HBO?
(I’ll crawl back into my hole now. :face_with_peeking_eye:)
Dancing on the bar! :grinning_face:
Wisdom of the Crowd!
Deer are just large rats, some with antlers. Shoot them and eat them like people did in the good old days.
Or tell you municipality to hire some professional shooters, and give the meat to the homeless. It’s good lean meat.:face_savoring_food:
A good handgun .357 Cal will take them down ASAP.
My v3 captured this last year.
That thing looks large like a cougar and spotted legs like a bobcat. So what do we call a bobcat-cougar mix? A Bougar? Bo[bcat co]ugar?
In the words of @Crease …
And I thought I had problems with ants😁
None of my Wyze cams will trigger based on person or animal. Some used to
We really need this in Alexa … for our Wyze cams. Basic capability for many cams.
None of my cams are able to trigger an event not even the ones that were working. Please assist. Thank you.
@tc10
If I look at my V4 triggers (Wyze Automations) I am presented with the following:
I do have Cam Unlimited Pro. I did not complete the automation as I suspect this Trigger may only appear if you’ve paid the money💵.
I’m not sure if this helps but I’m able to use just Alexa for the trigger. While creating the routine I select Smart Home and my V4. I’m presented with the following screen:
Are you seeing the same screen? If not then it may be tied to Cam Pro. It’s to early to test but I’ll try it when I can using the following Routine:
My V4 Kim’s get the same choices in Wyze automations as yours do.
My V4 cams in Alexa get an error message
Hmmm. I’m not used to seeing alexa allowing you to select something if it’s not available. Typically it’s greyed out.
I hate to suggest it but have you tried relinking. I’m nervous after an experience with yolink.
I thought of this last night as well … good suggestion … :thinking::crossed_fingers:
I just tried relinking … same error message :thinking:
I guess we start going down the list to see if anything is different between us.
Samsung S24 Ultra phone - - fully updated Android 15
Samsung a9+ tablet - - fully updated Android 15
Wyze app - - b690
V4 Device info - - see below
Alexa app–see below
I can’t believe it’s connectivity related so I’m holding off on networking stuff.
Your turn.
Thanks for assist
IPhone 15 pro current release 18.6.2
iPad 2025 18.6.2
Wyze app 3.6.5 (5) current
v4 device same firmware, different plug-in
Alexa same client & different build, Hostname different, same app version
The 1000lb gorilla in the room with us (wildlife, pun intended) . Your IOS, I’m Android.
Let’s see if we can get a 3rd party or two to see if it’s repeatable.
This smells like an IOS bug.
Not sure if you are already aware but Wyze and Alexa have been broken for Canadian Amazon accounts. You need an Amazon US account to have them working.
Send some Canadian smoke to Amazon Headquarters in Seattle until they fix the issue. :grin:
Being a smoker for about 50 years, I don’t think I have that kind of lung capacity :laughing:
Hmmm.
