Wifi from 2.4 and 5
If the issue is only during initial setup, you can force your phone onto 2.4, or disable 5ghz in your mesh system temporarily. I’ve seen quite a few of these systems that improperly block traffic between 2.4 and 5, or sometimes attempt to “band steer” a 2.4ghz only device onto 5ghz, which interferes with the sensitive timing of the setup process.
Carpentry is actually a decent trade. Yeah things have changed a lot over the years.
Thank you for your response.
