The view inside my bluebird house is limited. I would like a wide angle lens that doesn’t distort the image too much.
I took a stab and bought a lens from an Amazon seller. The lens threads into the mount just like the original, but in order to get the image in focus, the lens has to be screwed out to the last thread.
Here are photos of the replacement lens
This is the Amazon seller
[uxcell 12mm 5MP F2.0 FPV CCTV Camera Lens Wide Angle for CCD Camera https://a.co/d/1lXVSH6](uxcell 12mm 5MP F2.0 FPV CCTV Camera Lens Wide Angle for CCD Camera https://a.co/d/1lXVSH6)
I have this lens coming tomorrow. Again, I am guessing.
[Xenocam FPV CCD Camera Lens 2.5mm Wide Angle 170 Degrees Low Distortion Without Infrared Filter https://a.co/d/8CedJEV](Xenocam FPV CCD Camera Lens 2.5mm Wide Angle 170 Degrees Low Distortion Without Infrared Filter https://a.co/d/8CedJEV)
Focal length? Notice the second seller has a wide variety of lenses. The camera is mounted about 4” to 5” above the nest. I would like the image sharp from the nest up to the lens.
Any ideas which one I should get?
