Why my Wyze camera in Wyzebrigde not work?
Are there anyone good at this, i want to use wyzebrigde instead of wyzen app but the system keep show me that the camera preview not available, what should i do?
I have try to restart but it still not work while in wyze app, it still working.
Not sure if Wyze bridge has updated to support the new security protocols or not. If not, I don’t think the window cam will work with it as I don’t believe it has firmware from before those new protocols were implemented.
Wyze bridge is 3rd party software so you’d want to check compatibility with their documentation and/or forums. I believe Tiny Cam Pro supports the new protocols, but not sure about whether it supports the window cam or not (and it is paid software, albeit not that expensive).
