Ok so I’ve already posted before how my cam can’t read the sd card for past videos since then I’ve put high endurance ones in there and they work for a while but then stop as of right now it is saying that it’s not detecting the sd card I’ve even taken it out and put it in my phone to check if there’s something wrong with the card but my phone registers it
I ended up getting rid of one of my V3 pans, had 2
One worked fine with SD cards the other didn’t, even swapped SD’s between the cameras. It wasn’t the SD card.
Wyze just has junk built by other companies (OEM) and TRIES to make them work well with THEIR Firmware/Software. They do a Horrible Job that’s why the constant updates and issues.
Other brands work far better ![]()
