Why are my recordings often being truncated to three seconds
So I have a mountaintop house that’s so rural that the front porch camera doubles as a “trail cam”. Sometimes it will do a normal recording, such as this one that features a red squirrel (known alternately as a “chickaree” or a “fairydiddle”) that decided to flash the camera. He’s due to be placed on the sex offender registry list! :wink:
As you can see, it’s a normal length recording. But sometimes recordings get truncated to just two or three seconds with no explanation, when they clearly shouldn’t. The porch is also haunted by a bobcat no doubt wanting to feast on the fairydiddle (I caught her chasing the rodent under the porch one time), and recently she sauntered by only to have the event broken into three clips, each three seconds long…
Note that on my phone and the web viewer they come up as three seconds, but when I sent them to my PC so I could post them here a couple seconds of what appear to be random frames got tacked on to the end, making each clip supposedly five seconds. Maybe that’s a clue
At least much of the action was captured this time, albeit in pieces, but sometimes I’m not as lucky, and I only get two or three seconds of what was obviously a longer event. Also obviously, it’s not all the time, but these three clips should clearly have been recorded as a single clip. Can anyone tell me why this happens some of the time and how to prevent it from happening.
And for that “awwwww” moment, here’s said bobcat with a kitten one night!
Final question. Any one think my “animal porn” video at the start of this message is worth of the webby awards, or is it just too gross?
Great shots, especially the bobcat with the kitten. If you have Cam Plus, the clip is supposed to keep going as long as motion keeps being detected, so when an animal pauses or moves through a part of the frame outside your detection zone, the event ends and the next movement starts a new one. That would explain the bobcat getting split into three short clips. I’d try widening the detection zone and raising the motion sensitivity a bit, mainly for night. If the camera has a microSD card set to continuous recording, you can also scrub the playback timeline at that time to see the whole visit even when the event clips get chopped up.
If you send to your PC using the share feature from the WYZE app the last couple of frames may show “Caputred by WYZE Cam V4” or what ever cam you are using, (it used to and was annoying) I usually just download the videos then send them to myself via email if I am using my PC to post them on the forum or send them to someone else. If the downloaded files aren’t real large I just send them via my iOS devices.
I just tried the Share feature on a V4, still there.
My first guess would be a connectivity problem. Do you had SD cards, and if so, do those record the whole event? If your wifi connection is borderline, the buffer can run out and it has to stop cloud recording, but would still record to SD fine.
Also are you using stock power cables, or long ones? Running ones that are too long can cause odd issues like this too.
