Which outlet is which?
Just me grumbling about design again, but I have two outdoor heating devices (not ights where you can see them cycle on/off) hooked up to a Wyze Outdoor plug. But which is #1, and which is #2? Not marked on the outlet, Not on the body… it’s molded into the rubber flaps that fall off! Genius :slight_smile:
On the outdoor plug, the one on the left in Outlet 1 and the one on the right is outlet 2.
Note: there should be a light on the outdoor plug when an outlet is turned on.
