It’s important that my Cam 3s are not visible, or thieves will steal or disable them. One is mounted inside my home, one outside. Is it true that you can adjust the IR emitters for near or far and that one of these settings makes the camera’s IR emitters “invisible” to humans? And if so, which setting is that - near or far?
It took you longer to type up that request than it would have taken to test it for yourself. Set a V3 to Far and look at the camera in the dark and then repeat with the camera set to Near. Then you will know. I don’t remember and it’s broad daylight here right now so I can’t do a good test.
A check of the v3 product page also says this:
And a check of the support pages shows this:
https://support.wyze.com/hc/en-us/articles/360051152072-What-does-Near-and-Far-infrared-light-mean-
