Sticky spider adhesive micro droplet on a web strand very close the camera lens being illuminated by infrared light. You can see the web strand from top to bottom slightly diagonally.
Yep. Definately a node on a spider web floating in the air current. Something sticking to the web strand. What is great, is if you zoom in all the way, it almost looks like there are two organelles inside.
operated Drone.
Very cool the ‘face’. Amazing capture!
When you play the video, zoom in all the way on the object and look very closely in the lower left hand corner of the frame. You will see the anchoring filament moving with it. You most likely won’t be able to see it with the naked eye since it is only microns thick. It is only showing on the video because it is being blasted by IR light and reflecting back mere millimeters from the lens.
