Wyze WebView won’t work on my Chromebook
What are you experiencing? I have a Chromebook and don’t have issues with streaming. You do have to have Cam Plus on the camera’s, which I suspect you do as you indicate you can stream events.
Remember, this is still Beta. I have found, going into the events tab and then back again seems to clear things up at times. If it is spinning, refresh your page which seems to clear things up for me.
Thank you I’ll try that.
All the play button does is spin.
