How do I fix this - or is it something you need to work on?
Is it really that short? I have found it to be about an hour (never stopwatched it). HOWEVER, if you go to another window that covers the window with Web View, it will log you out when you come back to the Web View - sometimes. There is likely something more involved, but I have never tried to figure out exactly the pattern.
Yes - it does seem to be triggered by the use of other browsing pages - even on a separate monitor. Annoying.
They are working on it right now.
