WCO v2 & Solar Panel - charging trouble?
Do you watch the live feed? The camera should charge over 10% a day, but any energy you remove is taken from that.
Been 100% for 10 days!
Mine also randomly works then it don’t and yes it’s a wyze solar charger
Sometimes I disconnect it and turn cam in and off then it charges again till it don’t
I am just down at my parents’ place over the weekend and replaced the original cam with the warranty unit supplied by wyze Sunday afternoon (08/21). So far, it’s operating like the original cam did (during its first two weeks) and fully charging during the daylight hours to 100%. After the first two weeks of solid operation is when my trouble began with the original unit. Then, charging just became wildly unreliable & unpredictable. Early on, the wco v2 tanked from like 83% all the way down to 0% overnight. After that, it would stay in the single digits and bottom out. Got a couple of spikes followed by periods of depletion even during broad daylight with charging indicator showing. Not sure that I’ll have enough sampling time to say anything conclusively unless & until it starts losing charge and failing to charge.
Wyze also sent me a warranty solar panel since it was unclear which device might be at fault. My first instinct was to replace the cam only to see if we can isolate a culprit. However, I might just end up changing both at some point since I head back home this coming weekend.
Mine has been at 100% for about a month, and 4 days ago it randomly started dropping. Today it’s at 8%, Gunna let it die completely before I bring it in but I doubt it will recover this time on its own.
All my other v1 WCOs with solar panels literally next to each other, same event frequency, are at 100% and have been since I installed the panel.
Log: 712595
The warranty replacement wco v2 wyze sent me has also been operating as expected since I installed it back on 08/21. Stays fully charged during daylight and I don’t access it much after dark. We’ll see if it gives up the ghost or remains solid going forward.
My initial cam for this post would bottom out but then recover via solar panel charge. As I’ve documented in this thread, however, it was very sporadic how much charge it would regain. Nor would it ever resume regular charging as expected… Only when it was in the mood. :man_shrugging:t2:
So I have 2 v2’s. I bought 2 solar panels. Both began charging, but one slowed down and then stopped. The other went up to 100%. The other one did not show the charge icon. So I have turned off camera (rebooted), unplugged, re-plugged, checked both connections multiple times. I finally brought my camera inside to charge. Turned off the solar panel check box on the app since it was no longer connected. Charging in the house worked perfectly. After it increased about 10 % I turned it off, turned it on again, plugged in solar, turned accessory solar back on in app and it started charging for a while. Then for no reason the charge icon turns off and it stops charging and going down. I have updated firmware, I have rebooted the base station, I have reloaded the app and nothing helps.
So either the panel is bad, which I doubt. Maybe that little USB connector on the back of the camera contains some electronics that is not working properly or my camera firmware stinks and can’t figure out what the solar panel is doing. And yes, bright full sun no clouds and 90+ degrees outside.
I think this issue might be fixed for me. I haven’t done a firmware update, I haven’t touched the camera, the solar panel, or the connections, but lately the solar panel and my wyze cam v2 outdoor have been working perfectly together. Weird, just started happening out of nowhere.
Funny thing too, we’ve had crummier weather here lately, more clouds and rain. We had a lot more sunshine during the spring and summer, and that’s when I was having issues.
I observed similar inconsistencies as did you. Often, I would even see the charging indicator lit but no gain in battery… only a steady decline until bottoming out.
Thus far, the warranty replacement cam Wyze shipped to me has been behaving as expected since I installed it on 08/21/22.
I had both the cam and the Soler panel replaced 3 times every time Except this last time I did the updates cause they were new .
This time I’m nut doing updates on both cams v1 and. A v2 4 says still charging. Hopefully it’s fixed now and I won’t do any updates until It absolutely necessary.
I know the updates had to be the problem cause e2 other times I updated and the solar failed a few days later I’m going on 4 or 5 days no issues
I actually set this feature on as well the very first time I connected the original cam. I noticed that during some subsequent viewing sessions, the setting was switched back off.
Is this an example of the product disengaging by design for efficiency or does it just forget periodically?
I am not willing to call it solved, but WYZE sent me a replacement solar panel (full packaging). All I did was replace that 1 ft. connecter cable that plugs into the camera and then connects to the long cord from the solar panel. Works correctly now. I thought it was odd when I used the first cable that it seemed to charge, then quit. No wiggle, not loose from what I could tell, But this connector seemed a little tighter. So maybe they are having quality control issues with their manufacturing of the connectors. When I get time I am going to run some continuity tests on that little cable and break out my high powered magnifier to see if there is an issue with loose pins etc. Kind of tough with the micro size of the USB plug.
As a side note the other camera panel is working fine, except somehow the camera stopped responding and literally drained to nothing with the solar panel plugged in. Rebooted and is working again as should be.
I like WYZE, but the super cheap cost is probably causing them to suffer some quality issues.
TBH, another thing that has concerned me about the entire rigging of WCO & the solar panel is how they direct you to break off the rubber stopper with which the cam is equipped.
While I don’t believe they would secure it to anything sensitive and I’m sure it’s only connected to something structural, I snipped it with scissors on the replacement cam rather than just pulling it until it snapped.
In theory, this should not be happening. I have had 2 solar panels that power 4 cameras for quite some time, and I just checked mine – they were all still engaged, even those that don’t currently have a solar panel attached (I swap them back and forth every couple months). Might be worth keeping an eye on it to see if there is a bug, tho. BTW, I use the iOS app.
I did notice a bug on the iOS app just now, though. Apparently once you select installed, it says it is installed forever, even if the switch is turned off. I need to remember to write that up for the next Fix-it (first) Friday. :neutral_face:
Same trouble with my camera not charging with the solar panel. Worked for a time, then failed to re-charge.
I have 1x V1 and 1x V2 that both stopped charging with the Solar Panel. I disconnected from the panel for a day and then reconnected and both started charging. The V1 charges about 10% a day from 14% vs the V2 that charged to 100% from 9%
I’m not sure if it’s a discharge or capacitor issue. I have four total and two out of the four exhibit the problem.
Thanks. I will try this.
-John
Well after all this time, suddenly one of my two outdoor cameras has stopped charging even though both solar panels are side by side and it’s a bright sunny day today. So now my camera is at zero for no apparent reason. After all of this I cannot recommend the battery powered Wyze outdoor camera. I will steer people clear of it. My indoor cameras are great. I just wish Wyze would figure out all these issues and get it working as well as the indoor cameras.
you are enabling that within the camera’s options right? accessories option? also, ive noticed that between 5-7 weeks id have to go outside unplug the solar panel and plug it back in which fixed that issue… dont know how or why, but it does fix it (as long as its enabled within that camera settings). hope that helps. DeVoiD
Nothing has changed in over a month. Yes both cameras are enabled for solar. Both consistently stay around 100% with all the sun we have. In the morning yes they are less than 100% and when we had a day or two of clouds and rain. Both cameras are mounting inside a chicken coop with both solar panels facing perfect sun. So it doesn’t make any sense. I have replaced one solar panel due to the cord being defective. but now with no movement of solar panel, cords, or camera and no changes in programing, etc . Suddenly dead. I just put a new solar panel on the unit and will see if that works. Yes, I powered cycled the camera just to make sure. Also, last time I didn’t have to bring it in to charge from zero. The solar panel did that although it took a couple of days.
