Does it support Waze cam lite
Depends on what you mean, but probably yes.
Cam Plus Lite - Yes
Floodlight - yes
Spotlight - yes
Light Socket - yes
On the APP account services page it’s not listing my Waye v3 cam. So I can’t turn on people detection and 12 second video I don’t know why
I assume you show a Cam Plus Lite tab?
You pressed +Add Cameras at the bottom of the list?
If your V3 is not shown there, then maybe you have it on a Cam Plus free trial?
The V3 is not shared to you; you are the primary owner, correct?
Yes I pressed add camera but the camera is not listed. It is not shared I am the primary owner. I cannot add person detection because it won’t let me. No 12-second videos either
Did you have it on a cam play trial or something before? Unassign it from the cam plus tab.
Just to be clear, this is not a Pan V3 nor a V3 Pro, right?
It’s v3 pan cam The new one that just came out not pro
Wyze Cam Pan v3 Indoor/Outdoor IP65-Rated 1080p Pan/Tilt/Zoom Wi-Fi Smart Home Security Camera with Color Night Vision, 2-Way Audio, Works with Alexa & Google Assistant, White Amazon.com
Not supported with CamPlus Lite.
Yes, this is not a standard V3. Only the original V3 plain is supported by Cam Plus Lite.
Okay thanks for that information
Scroll down near the bottom of this link for a list of cameras the work with Cam Plus Lite.
Thanks again
