Its possible to move or change the visualizer order in the app
Welcome @pablo.mercado
Yes you can:
- Start the app
- Tap on the Pencil in the top Right on the main Home Page
- Select Edit Devices
- Then simply hold the icon on the right, 2 lines on top of each other like an equal sign, and drag the device to the spot you want it on the list
- Then click Done in the top right to save it
Hope this helps
Excellent thanks
