I can view some recorded events but most say “failed to load from local storage”…
got recorded sound events …how do I playback?
any help please.
any help please.
If you’re having problems linking to the SD card playback, you can load it manually by loading the camera from the Home Tab, then you can click on “SD Card” to load the playback there
Then it will show up just below the live stream:
It will show you on that timeline where all your events start.
Be sure you are set to Continuous recording on the SD Card camera settings > Advanced Settings > Record to MicroSD Card ON and CONTINUOUS to make sure footage is always available.
thanks…I was doing that but still “failed to load…”
thanks… they are all set up…ican see in the timeline that there are recordings but the fall to load from my sd
