I have a Wyze Video Doorbell v2 that I installed in May/2026. It was working fine until August/2026. The problem I’m encountering is that it is showing offline in the mobile app and on the website, but when I look at the device info in the mobile app I see that it has a valid IP Address and signal strength is good.
I checked the SD Card and it is recording.
I went through the troubleshooting steps provided by the support line (AI system) that keeps repeating the same instructions. Is there a way to speak to a human to possibly got my device replaced?
If the doorbell is showing offline but functioning normally, i.e. live view thru app, recording to sdcard, reflecting offline is not going to get you a replacement. There is an apparent communication issue between your router and the doorbell.
Should you desire to pursue getting a replacement, you need to start by creating a log id in the app and submitting it to tech support which will create a ticket for it.
Have you recycled/restarted your router, phone, app and cleared phone and app cache?
Perhaps if you list/post the troubleshooting steps you have performed, it may give better insight into getting some good suggestions from Wyze Forum users.
Since it shows Offline on the website as well as the app, clearing the phone cache alone probably won’t flip the status. The camera is clearly online enough to report IP, signal and keep writing the SD card, so this looks like the cloud status flag is stuck. I’d submit that log ID to support and note those three details (valid IP, good signal, SD still recording, Offline on both app and web), because that combination usually gets past the scripted reboot loop.
After contacting the number Jason provided; I was able to reset the doorbell camera and successfully reconnect it.
Thank you all for your supportive responses.
