v4, trying to activate the SD recording. Gear, Advanced Setting does not appear. Shows: Cameras in group & Show Camera Name & Automations, only. In Basic package, how can I set it up to record?
It sounds like you’re tapping the gear icon at the group level. You need to tap the single v4, wait for the live video stream to display, then tap the gear icon on the cam’s live stream page.
Good info. It worked… thanks.
No problem… glad to be of help.
