V4 switching from HD to 2.5K
Brand New V4 sits directly underneath Fios router. It keeps switching to 2.5K from HD. Signal strength is good. Is this a “Too many things using the same band” issue?
Odd, many people have an issue where it switches to 360. The glitch there seems to be if you leave it on the live stream then switch to another app, when you come back it is at 360. Maybe yours is the same bug but presenting a bit differently?
However “directly underneath” a FIOS router is a bad spot for wifi. Those routers broadcast mostly outward to the sides, and some above, so it may just be too close.
Well, may that’s the issue, that it’s underneath. Unfortunately, though, that is the only place it can be.
Are you complaining that the resolution gets better or is it a typo, or am reading it wrong.
Did you mean it’s switching from 2.5 to HD. If so @dave27 is spot on.
