V4 not connecting to cloud
Hi everyone
I’ve had my V4 for a year now capturing beautiful auroras. When I look at the motion clips they all say 0:00. When I click on it, it says failed to load from cloud server. You can view event from backup local storage.
Internet speed is the same and we are running 1G and I have 2 bars which has been consistent for my cameras location. So I don’t think it’s the connection.?
Please for the love of all that’s holy what do I need to do to fix this. It started on Aug 1st is where I can see the difference.
Thank you in advance for some suggestions.
Oh I did order a new V4 just in case and a Micro SD card is coming soon.
Have you tried power cycling everything? I would pull the power cords of your camera, WiFi Router and modem for a minute and see it helps.
Hello
Yes I have. I haven’t tried doing a reset in the app. Should I try that next? Or physically on the camera itself, maybe reset and start as new?
Thank you
Paula
If you power cycled everything with no luck, next i would try moving the v4 Temporarily next to you WiFi router just to eliminate signal strength as a problem.
I always use the Reset button on Wyze cameras as a last option.
If you haven’t tried - do the “reset services” in the app under the camera settings. That re-synchs stuff with the cloud. If not that then probably go to the full factory reset.
Note that after resetting services, your detection/notification settings will be reset to default so if you’ve customized those you’ll need do set those back.
Okay thank you.
Nothing has changed with the WIFI. So I will check.
Thank you
Paula
I did the reset earlier, Also, I’ve turned it off then on after 30secs.
Next I will just factory reset or delete camera and start over, hopefully that will clear the issue. I will take my SD are out though right?
Thank you.
Paula
Update:
I pulled the SD card out. Deleted camera but saved cloud. Next I Added camera, started the push setup button and started all over. Followed prompts.
It seems to be working now. If it wasn’t, Next, I would try deleting cloud too in case of some kind of glitch in the matrix lol!
Note this all started around Aug 1st when spectrum internet went crazy.
Thank you so much for your help!
Paula
