V3s cameras no longer record comtinuously to SD card
I have 2 V3s. I have both set to record continuously, but neither one does. They record events, though
When I go to SD Card, it shows the events, but no timeline like before
Did they remove the ability to do this wiithout paying?
No, they have not changed that. They have changed the UI for the V3 cameras and MANY people have failed to use the new UI properly. How are you trying to access your SD card recordings?
Also, in the Settings of each camera go to MicroSD Card and make sure “Continuous” is White and “Events” is gray.
I go to SD Card.
This is how I have it set
So there is no video (green bar) on the timeline between events? If you try to play something in between, it says “no video available at this time”?
Try doing “reset services” on one of the cams. If you’ve customized your detection/notification types, you’ll need to go do that again, but that can help when settings don’t seem to be synching with the cam properly.
