V3Pro Firmware 4.58.13.2340 Doesn't work with WebView...Again
I have many v3Pros, 10 online at the moment, not one will connect with WebView.
I moved your post to the Beta category and fixed your firmware version typo as 4.58.13.2340 is beta firmware.
You may wish to submit a log and post the Log ID to help devs debug. Or revert back to production firmware if web view access from v3 Pro cams is critical.
Do you have other camera models that are connecting to the web view still?
If you only have have V3 Pros, will you go the account tab and services and see if it shows something like Cam Unlimited Pro there? I ask this because We had another beta user experience something similar and it showed that on his account and we were able to get that resolved for him.
V2, pan cam, V3, floodlight, floodlight pro, and v4s all connect for me.
Just Unlimited, no Pro in services,
Same for me ‘again’ with Beta version
Logs submitted,
1724141 through 1724150
@Seapup
@carverofchoice
More logs submitted
1724865 through 172487
@bonenfant.patrice
Could you submit logs?
Easy peasy on the Webview page.
@Seapup
Just a fyi, going into my cam’s settings, device info, firmware version screen, it does not show (beta) in the info.
Log submitted ID 1724901
You won’t see “beta” after the fact. “beta” is only denoted when update is available and immediately after updating on the firmware update success page.
Well apparently, without a word, they changed something on the back end, or webview side, as the v3p’s now work on webview.
I am seeing that anything over 15 cams at a time (less if floodlight pro’s are included) on Webview I start getting lots of cams not connecting, or connecting but hanging (frozen, clock not advancing).
I watch my router, and outgoing traffic never really goes over 4Mbps except when doing a speedtest, where it goes over 40Mbps. While viewing 15 cams, the max transmit of my router (Ubiquity EdgeRouter4) is about 600Kbps, nowhere near the 40Mbps it easily runs at.
It seems that 15 cams (mix of v4 and v3p) is the max of viewing at once without them starting to freeze.
New 2000/300 service with new router (Dream Machine Pro SE) and modem and access points scheduled to go in this weekend, but I get the feeling the bottleneck is not me right now…
I have two access points that are made to handle 200 concurrent clients each,…
This build crashed one of my V3 Pro cameras. It will no longer connect to any wifi network. When I try to flash a different version of firmware, the camera boots up as normal. When I try to add the camera via the Wyze app, it takes about 5 seconds and says can’t find network. Customer Support has let me know tough luck, buy a new camera as my camera is 6 months out of warranty.
