V3 pro settings don't save
I just got my two pack of V3 pros. One of them I have no problem with but the other one won’t save any settings. I needed to turn it 180°, but it says settings not updated. I deleted it and reset it and reinstalled it over and over and nothing I do gets the settings to save. I can’t get rid of the wyze logo or save any of the other settings such as the status light or timestamp.
What’s the signal strength on this cam? Also, are you able to reliably live view it?
Spoke to a representative and was told that this is a known issue with the new cameras and they’re going to be putting out an update in a week or so. I got the two pack and one of them works and the other one doesn’t so it is just this one camera that I have a problem with. Thank you for replying so quickly.
