V3 CamPlus event recording settings can be confusion
on firmware 4.36.9.139 it is possible to turn off motion detection in event recording and still access the CamPlus AI settings. this can mislead users that the CamPlus events will still work when they will actually will not. I was going to simply suggest to either grey out the CamPlus settings when motion is off under event recordings, or add the V2’s radial option for AI events only.
The newer 4.36.10.xxxx Cam V3 firmware introduced the same UI as you are seeing in the V2.
As soon as 4.36.10.xxxx is approved for a full release to all V3, you will see it as an OTA available update.
