V2 Motion Sensor versus v1
What is the angles the v2 motion sensors can detect? I had a v1 sensor at the top of my stairs to turn on the 2f hall lights while climbing the stairs and it worked fine. The v2 sensor in the same place doesn’t detect until I’m all the way at the top.
You are walking to fast for the V2s. Give it 40 years when you are older and slower and can’t help it. Then they will have enough time while you are, like me, still on the second step.
Sorry. Could not help myself. I plead old as the cause. Really sounds like the V2’s are slower. Don’t know how to make them faster.
Sure the V2 isn’t mounted upside down?
It’s all in the Support pages for the products.
V1
V2
