I have 3 v2 in the beta firmware and my friend has 2 v1 in the beta firmware, I have the night vision IR toggle but my friend doesn’t, is this normal or the v2 and v1 has more differences than the CMOS, motion tagging and audio chip?
Thanks.
Thanks.
I believe they said that the toggle would only be available for V2 and Pan, not V1.
Thanks for your reply.
that is correct. the V1 is not supported only due to hardware limitations.
but hey, it is a reason to upgrade
