Upgrade failing
The latest firmware upgrade keeps failing. Wired and battery cam pros, as well as chime for pro doorbell. I tied resetting the chime, same issue.
How are you trying to upgrade (updating through the Wyze App or Manual Flashing of camera firmware)?
Thru the app, no mods I have 25 Wyze cams but the pro battery cams and one chime keeps failing. Of course the chime doesn’t use batteries, Also tried resetting and replaced batteries.
You could try manually flashing the firmware if you have a camera on this list that won’t update.
https://support.wyze.com/hc/en-us/articles/360031490871-How-to-flash-your-Wyze-Cam-firmware-manually
