IR Light … its great we can now avoid window reflection by turning off the IR light…thanks for that…has anyone noticed a change in their push notification since the update? I am not getting mine now…is there a Quick Resolve for the issue?
ok found it… for those that didnt know you will have to go to app settings and turn back on your notifications…if you updated or upgraded your firmware…
