I have one group with four Wyze smart bulbs in it.
My challenge is that I’d like to add a second group containing 2 of the bulbs from Group 1, but with schedules set that do don’t overlap Group 1. How can I accomplish this ?
Group 1- on sunset, off 9:50pm- bulbs 1,2,3,4
Group 2- on 9:51pm off sunrise- bulbs 1 and 2 only.
Wyze devices can’t be in two separate groups at the same time. They can only be in one group and they can’t be subgrouped.
EDIT: I just thought of a simpler way without modifying the 4 bulb group: just create a second schedule rule for on at 9:51pm off at sunrise and select the individual bulbs 1 & 2 as the devices, not the entire group. Otherwise
You will need to remove bulbs 3 and 4 from the 4 Bulb Group and create a Bulb Group B, renaming the original group Bulb Group A (bulbs 1 & 2). Then add Bulb 3 and 4 to Bulb Group B.
Go to the original schedule rule for the 4 bulb Group “On at Sunset”, and modify the Devices so that it reflects the same command (I assume you use Turn On) but you will select two device groups: Group A (bulbs 1 & 2) and Group B (bulbs 3 & 4).
Create another rule schedule rule for on at 9:51pm off at sunrise but only select Group A (bulbs 1 & 2) as the device.
In addition to what @SlabSlayer indicated above, you can actually setup a rule and then set the action on the individual bulbs.
so basically, you can leave Group 1 alone and the instead of using Group 2, your Rule would Reference Bulb 1 and 2 for the actions independently. Especially on the Off option.
@SlabSlayer@spamoni4
Thanks for taking the time to think this through for me. I’ll attach the two rules. I’ve set up based on your input. Thanks again.
