I have wyze devices in both my home and vacation home. Can i put them all on the same app?
Sure! Add them to the same account. It should work the same way it does now when you’re away from home .
Yes and no…which devices? If you need the Home Monitoring System the answer is no. If you mean just cameras, plugs and the like. then yes.
themdg and WildBill (I think) answered your correctly. Yes. But for future reference, let me ask you a question. If you could not, where would you put the other if not on the same app?
You would still use the same app, but a different account.
No, no need for that. One account works at multiple locations.
