TV input changes when asking Alexa to view camera through Firestick 4k Max
Using a Firestick 4k Max…when I ask Alexa to view a Wyze camera it says “OK” and then the tv input changes. If I go back to the first input the view is there and all is good. Why does it change inputs?
Welcome @garyjabo
Depends on the settings for your TV. Most TV’s will sense that something is active on a connected device and automatically switch to that input. You can turn this feature off on many TV’s, if you wish.
Here is a Site which explains it some:
Why Your TV Keeps Changing Inputs by Itself (Easy Fix) (smarthomestarter.com)
Thank you. That fixed it.
Gary Jablonski
