Tinycam pro pushed an update and no live view on WYZE cams since
Hello all,
This is just for awareness as it appears to be an issue on the tinycam side of things.
tinycam pushed through an update (version 19.0.2) and since this update, none of my 10 WYZE cams will show live view anymore.
I have already sent out a life-line to the tinycam developer to report the issue on the developer’s reddit page announcing the new version release.
Here is a copy/paste of what I sent:
Since the update pushed through, all 10 of my WYZE cameras won’t show live view anymore.
4 cam v4’s
5 cam v3’s
1 cam OG
Sometimes one or two of the cameras will start to work and show a live view for a few moments and then go back down again. Some of them will not go live at all, not even for a moment.
I’m using a brand new Amazon Fire HD-10 13th generation tablet that I just purchased in July so it’s not an old device.
I have tried clearing the cache, force-stopping and re-starting the app, restarting the tablet, none of it has made a difference.
Are there any kind of bad communication issues between WYZE and tinycam since the update that need to be resolved or are there just general issues with the update?
Please help.
Thanks.
Here is the tinycam developer’s release page on reddit if anyone wants to follow it:
tinyCam 19.0.2 released
19.0.2 on phone and tablet with no problems. Did require re-logon to wyze.
(v2, v3, and v4)
The only way I was able to get live view stability back was to go into settings and:
Change the Stream Profile from “Main” to “Sub”
Change the video decoder to “Software”*
Switch away from 10-camera view pattern and use no more than 7-camera view pattern
So far after doing this, everything has been pretty stable. I don’t think I’ve had a single camera view drop yet in about an hour since the adjustments.
I think even on sub stream setting, my Amazon Fire HD-10 13th generation with only 3GB of RAM is just not up to the task of handling a 10-camera view pattern without issues, which is definitely not tinycam’s fault. So unless and until I get a more robust device to handle it, it looks like the 7-camera pattern view is now the most it can handle, which I’m fine with. I’m just glad it is working again.
